7MGTE strange A/C symptom
Alang
55
Las Vegas
What's going on?
Did an LV - LA run with the A/C running on recirc air. Outbound cruise 3500 rpm. Late in the run the seemingly cold air would not cool the interior. The upper interior air became very warm. I relieved it only be opening the windows.
On the return cruise @ 3000rpm, I got a bright idea. When the same symptom happened, I shut off the a/c for a while, set the temp at its lowest and with fan only it continued to cool the interior. After a bit, I restarted the A/C and it worked fine. Did this same cycle 2-3 times more on that run.
Is something icing up? Compressor at high speed issue? ???
8,898
If it cools down after being shut off a while, it is probably icing up. You could have a very small leak and it is drawing in moisture.
bluepearl
326
pa.
Also, if the evaporator is icing up, you will have alot of water coming out of the drain on shut-down. (if it is not blocked)
