7MGTE Problems HELP
BOOSTEDMKII904
21
jacksonville fl
So I have been having problems with my 7mgte the car idles at about 1000 after warming up and when I get on it a little the car cuts off some times and sometimes it doesnt.I think its my ISC sensor but im not sure any help would be great.
jonahs_supra
1,015
Lancaster, Ohio, United States
No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked.
It is a rpm signal problem but not for that circuit.
Either the cps is bad or the wiring. Cps wiring usually goes to shit from all the heat. Have to test the wiring to the ecu to find out of its good. A simple resistance check will tell you that.
