Hi I am doing a motor swap into the Cressida, I boutght my freinds 89 supra turbo and swapping everything. I dropped the motor in and the mounts were changed to the cress due to the front sump but the 7mgte has a different oil filter mount that is in the way of the cress engine mount, so I bought an oil filter relocat kit. So my question is can the relocate kit work with stock oil cooler since the mount is different. The supra has a line that feeds oil cooler then dumped into pan, so the relocate kit will have the line feed the cooler and so on like stock. Is this good cuz I seen other do it with a bigger oil cooler, I just want this swap with minimal upgrades using stock oil cooler???
