7MGTE auto to manual R154 conversion HELP!
toastem2
poop slut
Oct 30, 2006
11
Des Moines, Iowa
:1zhelp:
hey guys, I've been working on this conversion for like a year and a half, haven't had time to finish it until now.
I got the tranny bolted up, pressure plate bolted on, master and slave cylinder hooked up, starter on, wiring all done and hooked up...
I got to the driveshaft and its kinda weird, I put the sleeve yoke of the driveshaft onto the output end of the tranny... slides on fine,
but I bolted on the center berring and the flange yoke onto the diff and there is like a 1 1/2" gap where the sleeve yoke is visible, but still firmly attached to the tranny... is that normal?
or do i have a wrong driveshaft? it doesn't leak or anything i'm just a little concerned its wrong???
Also since it hasn't been ran for almost 2 years, what should i do before I start it up?
1. Change oil
2. Drian old gas, put new in with an octane booster
anything else?
toastem2
poop slut
Oct 30, 2006
11
Des Moines, Iowa
yaa I did, i had them side by side (the auto and manual driveshafts) and i couldn't see a differance, so i tried sliding each of the yolks onto the tranny and only one would go on... so i used that one
i dont think the auto would go on, cause they have a different amount of splines right?
Idealsupra said:
did you swap driveshafts to a manual one?
tte
Breaking In - in progress
Northern California
Your best bet is to find a Supra guy who lives in your area and know how to do the conversion. That way you will feel confident that it is done right and also it will be done alot faster.
Cheers,
Roy
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
you have the auto driveshaft. you're gonna want the r154 driveshaft. i actually need one myself, because i'm doin the same swap. =0)
-t3d
toastem2
poop slut
Oct 30, 2006
11
Des Moines, Iowa
the guy i bought the tranny off of (R154) also sold me the manual driveshaft for it... maybe i'll try the other one see if it works...
neone in Iowa have a R154 driveshaft to part with?
-t3d
