7MGE - Radiator Fluid Lead from transmission port
Jeff Lange
Administrator
4,923
13
Sunnyvale, CA
jefflange.ca
The question is how/why is it leaking. Is coolant leaking into the oil cooler inside the end tank and that is coming out of the port, or is the port itself leaking? A cap will only help if somehow the coolant is getting inside.
Did the 90-degree fittings that came with the radiator come installed and you removed them? Any chance you loosened this nut/fitting as well when doing so?
Jeff
MadNad
46
Lafayatee, CA
Ah yes, I have a manual transmission. I did not remove any fittings. This is leaking from the port itself. You raise a good point though. Is it coming from out the port or the port itself is leaking from the outside? I'll see if i can snug up the fitting. I feel like this has been leaking the whole time since installing the radiator. I thought maybe I had a small leak in the heater core as I would occasionally smell fluid.
