7m GE Engine removal?
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
I know theres a guide in 49 easy steps on here, but thats for a GTE. Wheres the step by step for GE? I wanna make sure I got everything.
thanks guys, and I did try searching, really having problems there.
JBatt87T
102
Athens, GA
Just disconnect everything holding it in and pull that sucker out. Or if you wanna use those steps just disregard everything about the turbo removal. Easy as pie.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Only thing Im missing is fuel lines, is there a single place where I pull a fuel line?
Other than that all I have left is water pump hoses, crossmember, speedo cable, and whatever else is on the tranny.
mkiiSupraMan18
Needs a new username...
United States
Yeah, easiest spot is the frame rail on the drivers side. It should all be under a little platic cover. Probably gonna need two pairs of vise grips to get it off. One just pulls off w/ a little wire clip thing.
OR, you could remove them both from the engine, but thats a flippin PITA.
Those steps are the same... you just got a few less bolts to take off.
