550cc vs stock. how can i tell?
BOOSTEDSUPRA
THE DRIVELINE GUY
Jan 4, 2007
308
turlock, calif
ok, i have 2 mkiii sups. one 1990 that has a bad turbo and has the lexus afm on it, and was told 550cc injectors. i know one way to tell if there 550 is to look for the new clips splice in. i do not see that. are there plug and play injectors? can they be the injectors off the same car the afm came from? if so how would i tell? i am inquiering cause i want to put them on my 87 which has more mods and runs fine, and to sell the 90. any help would be great, and thanks again in advance from your friendly neiborhood supraman! :)
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
The plug and play injectors are Denso's, and possibly some HKS units. The Denso's have a pinkish red color to the top area.
Zach
ECUMaster USA
Apr 6, 2005
375
TX
You crank up the boost on the car and hit the dyno.
If it leans out and blows up at 450whp you've got 440's
If it leans out and blows up at 550+whp you've got 550's :)
Best and safest way is to send them out to be cleaned and flow tested. That'll give you guaranteed info and peace of mind.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
I misread your original post. You shouldn't put post 88 injectors(high impedance) on a pre-88 car(low impedance), because the injectors will be slow to open/respond(though you can put low imp.'s into a later car). If you want 550's in your 90 car, best to go buy some.
