410 vs 373
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
i have a 1ggte supra that was originally an na it still has the automatic rear end that came in it with the 410 posi it seems a little low geared like i need another gear when im on the interstate so my bro. has a 91 turbo 5spd rear end 373 which is better my 410 auto or the 373 5spd i think with the 410 i have better low end speed but with the 373 ill have better top end which is better and is there a happy medium?:1zhelp:
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
N/A's have 4.30:1
87-88 Turbos have 3.91:1
89-92 Turbos have 3.73:1
You should have 4.30:1 right now. I think 3.91:1 or 4.10:1 would be the happy medium you are looking for.
OneJoeZee
Retired Post Whore
aboard the Argama
jeff, do you know if the 89 year was split with diffs like they did motor mounts, crank and all those other pre or post 89 traits?
like is it common for an early 89 (like mine) that originally had square mounts and a 6M crank 7M to also have a 3.91 diff?
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Jeff Lange said:
N/A's have 4.30:1
Is the 89-92 Turbo with an Automatic also a 3.73?
My car was converted to 5speed and was a turbo model , just curios.
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
Nope, all 89's should have the 3.73 diff.
Automatics and Manuals had the same diffs.
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
87 n/a if its the LSD not the OPEN would be better if you want it for quater mile. Make sure its from an n/a with the sports package. Only a few of us get so lucky.
