3" exhaust flange to 2.5" ???
Apr 13, 2005
64
Jacksonville, FL
I got this header for my na. It was designed to work with a 3" cat back so from the cat back it's 3" pipe yet my cat-back is 2.5" so it doesn't fit. Big exhaust leak. I failed to remember this when I purchased the header. What are my options here? is there some sort of metal gasket I can purchase that has a 2.5" opening? Or is my only option to take it to a muffler shop and have a new flange made? The 3" pipe is welded to the cat as well so I can't just remove it.. thanks.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
Have the muffler shop make you a test pipe with a 3" flange on one side, and a 2.5" on the other.
Either that or go full 3"
all the backpressure you need is located in the manifold.
Apr 13, 2005
64
Jacksonville, FL
The header pipe to cat is 2.5". I think the test pipe idea sounds like what i might have to do. I don't see many other options unless I go 3" exhaust. I'm really trying not to spend too much. Don't have emissions in florida so won't have to worry about the cat.
