2JZGTE Part Numbers!
CSquared
Atlanta, GA
Found this on another site and thought it would be a good resource to have... There are two different lists with mostly the same parts (first list in black font and second list in blue).
Accessories Front End Mask 00218-14930
Accessories Wheel Locks 00276-14930
Accessories Floor Mats BLACK/Ivory Logo 00200-14930-08
Accessories Floor Mats Blk/Silver Logo 00200-14930-13
Accessories Floor Mats Blk/SE Logo 00200-14950-01
Accessories Carpet Clips, Pack of 2 00208-00801
Accessories 97/98 Dash Instrument Panel Bezel Center Upper 55410-14530
Accessories 97/98 Dash Instrument Panel Bezel lh dash, Left Side 55404-14570
Accessories 97/98 Dash Instrument Panel Bezel Speedo Bezel 55420-14060
Accessories 97/98 Dash Instrument Panel Bezel Radio/HVAC Panel 55405-14170
Accessories 97/98 Dash Instrument Panel Bezel 6spd Shift Bezel 58804-14100
Accessories 97/98 Dash Instrument Panel Bezel ATM Shift Bezel 58804-14110
Accessories 97/98 Dash Instrument Panel Bezel lh Door Switch Bezel. Left 74232-14121
Accessories Driver & Passenger Visors w/ Black Cloth / Black Cloth That Goes Above it (The One Around The Dome L 74310-14640-CO, 74320-14700-C0, 63310-14690-C0
Accessories Driver Side Moldings On A pillar & Targa 62220-14090-C0, 63218-14020-C0
Accessories Black Carpet, Floor 58510-1B171-C0
Accessories Front Left Defroster Vent 55961-14090-C0
Accessories Aluminum gauge bezels 08172-14020
Accessories Mud Guards Front 76621-19255
Accessories Mud Guards Front 76622-19255
Body Glass Headlights (RIGHT) 81130-1B220
Body Glass Headlights (LEFT) 81170-1B220
Body Center Caps 97-98 42603-14350
Body Euro Hood scoop 76181-14900
Body Euro Hood scoop guide, hood air intake 76182-14010
Body Euro Hood scoop protector hood scoop, No. 1 76183-14010
Body Euro Hood scoop protector hood scoop, No. 2 76184-14010
Body Euro Hood scoop retainer,hood air intake(2) 76187-14010
Body Euro Hood scoop plate,hood scoop 76192-14010
Body Euro Hood scoop screws (8) 93567-14512
Body Euro Hood scoop nuts (4) 90179-06058
Body Euro Hood scoop seal,hood air intake 76186-14010
Body 96 passenger side rear view mirror, non heated 87910-1B131-C0
Body Fuel Door with hinge 77350-14081
Body Weather/strip Under Hood 53383-14120
Body cowl pane{blk plastic] between the windsheild and the hood 55708-14030
Body wheel well splash sheilds 53875-14190 rh liner, 53876-14190 lh liner
Body Hatch Stay w/spoiler (RIGHT) 68950-19895
Body Hatch Stay w/spoiler (LEFT) 68960-19585
Body Hatch rubber stopper [stops the squeak] 67293-14051
Body Hatch rubber stopper screws (2 each) 90159-50116
Body targa roof 63201-14060
Body targa mld rh 63217-14030-C0
Body targa mld lh 63218-14020-C0
Body targa w/strip rh 62383-14030
Body targa w/strip lh 62384-14030
Body targa headliner 63312-14050-C0
Body targa bolts frt 90901-09004
Body targa bolt /brkt rear rh [2pc brkt w/bolt] 63240-14090
Body targa bolt/ brkt rear lh [2pc brkt w/bolt] 63240-14060
Body targa ctr.lock assy 63203-14100
Body HELICOIL KIT FOR TARGA BOLTS 5546.6 [6mm x 1.0]
Body turbo spoiler rear 76085-14909
Body frt glass mld 75533-14190
Body back glass mld 75573-14210
Body floor carpet [ stick/ivory] 58510-1B171-A0
Body floor carpet [stick/black] 58510-1B171-C0
Body floor carpet [auto/ivory] 58510-1B181-A0
Body floor carpet [auto/black] 58510-1B181-C0
Body rear lisc.plate nuts 52121-24020
Body tonneau cover trunk 64910-14060-C0
Body power antenna 86300-14411
Body power antenna mast only [chrome only] 86337-14411
Body ash tray [93.5-96] 74102-14130
Body ash tray [97-98] 74102-14140
Body Front Lip Spoiler 76851-14060
Body Hood 53301-14340
Body Front Bumper Cover 52119-14921
Bulbs & Lights Toyota 3rd stop lamp 81570-14060
Bulbs & Lights Toyota 3rd stop lamp 81570-14061
Bulbs & Lights Toyota head lamp lh 81151-18241
Bulbs & Lights Toyota head lamp rh 81111-18241
Bulbs & Lights Toyota tail lamp lh 81561-14700
Bulbs & Lights Toyota tail lamp rh 81551-14700
Bulbs & Lights Toyota t/s lamp frt rh 81510-80086
Bulbs & Lights Toyota t/s lamp frt lh 81520-80086
Bulbs & Lights Toyota t/s frt harness 81515-14390
Bulbs & Lights Toyota turn signal/hazzard flasher 81980-12070
Bulbs & Lights Low Beam Headlamp 9006
Bulbs & Lights High Beam Headlamp 9005
Bulbs & Lights Parking Light 168
Bulbs & Lights Front Turn Signal 1156
Bulbs & Lights Rear Turn Signal 1156
Bulbs & Lights Tail Light 1157
Bulbs & Lights Stop Light 1157
Bulbs & Lights Fog/Driving Light H3-55w
Bulbs & Lights License Plate 168
Bulbs & Lights Backup Light 1156
Bulbs & Lights Front Side Marker 194
Bulbs & Lights Rear Side Marker 194
Bulbs & Lights Glove Box 37, 74
Bulbs & Lights Trunk/Cargo DE3022, 194
Bulbs & Lights Instrument/General 74, 194
Bulbs & Lights HVAC Cluster Bulbs - Toyota 84999-70009
Bulbs & Lights Map Light - Toyota 90981-12005
Bulbs & Lights Trunk Light (93.5-96) 90981-11021
Bulbs & Lights Trunk Light (97-98) - Toyota 00234-13050
Bulbs & Lights Ash Tray Bulb - Toyota 90981-11018
Bulbs & Lights Ign Cylinder - Toyota 90981-11014
Bulbs & Lights Main Dash Cluster (large bulb green cap) 83109-24020
Drivetrain Getrag 6spd tranny 33030-0W212
Drivetrain Silicone Trans Sealer 00295-01281
Drivetrain atm screen filter 35330-30011
Drivetrain atm screen filter 35330-50010
Drivetrain drive shaft 37100-14810
Drivetrain Drive Shaft 37100-14820
Drivetrain Rear Diff. Pinion Seal 90311-50018
Drivetrain rear diff pinion seal 90311-44005
Drivetrain rear diff axle seals 90311-45013
Drivetrain rear diff axle seals 90311-47008
Drivetrain output shaft seal 90080-31029
Drivetrain shift rod case seal 90080-31032
Drivetrain Auto Tranny spacer,drive plate 32116-22020
Drivetrain 6spd Tranny seal input shaft 90080-31031
Drivetrain Trans Mount TT 6spd 12371-46110
Drivetrain Trans Mount TT Auto 12371-46120
Drivetrain 6spd Differential 41110-14780
Electrical Main Engine Harness 82121-14880
Electrical Optima Orange Top 800-R
Electrical Optima Orange Top 34R-1050
Electrical Ignition Coil Packs 90915-02205
Electrical Ignition Coil Pack Connectors (plastic) 90980-11246
Electrical EGR Resistor - Radio Shack 271-1126
Electrical VDO Boost Gauge 2-1/16" VDO-150121D
Electrical Ignitions Coil (NA 93.5-97) 90919-02207
Electrical Ignition Coil (NA 98) 90919-02216
Electrical Battery - Car 00544-24F60-575 group 24F
Electrical Keyless entry remote (non-toyota part) ECR2025
Electrical Keyless Entry Harness Kit 08586-14830
Electrical Keyless Entry ECU Kit (96-98 only) 8585.00921
Electrical Starter, Reman. 28100-46140-84
Emblems gold NA kit 00211-14950
Emblems gold TT kit 00211-14970
Emblems gold SE kit 00211-14954
Emblems gold SE logo only 00211-14953
Emblems gold ctr cap logo 00211-00951
Emblems gold ant. nut 00577-35950
Emblems gold "logo"frt 00211-14956
Emblems gold "toyota" 00211-14951
Emblems gold "supra" 00211-14952
Emblems gold "logo"rear 00211-14957
Emblems 15th anniv.logos 00211-14971-01 blk
Emblems 15th anniv.logos 00211-14971-28 silver
Emblems SE side stripes rh 00211-4R951
Emblems SE side stripes lh 00211-4L951
Emblems turbologo 00016-23940
Emblems frt cover "logo" grey 75314-14010
Emblems tailgate "toyota"grey 75441-14190
Emblems tailgate "logo" grey 75471-14010
Emblems tailgate "supra" grey 75442-14280
Emblems tailgate "supra turbo" grey 75443-14180
Emblems trd 3pack logo 00602-42601-EMB
Engine Oil Pressure Sensor Mod union bolt 90401-19008
Engine Oil Pressure Sensor Mod gasket 90430-20016
Engine Oil Pressure Sensor Mod o ring 90301-68005
Engine Exhaust lock nuts 90179-08059
Engine Exhaust lock nuts 90179-10070
Engine Exhaust bolts 90105-10023
Engine Exhaust nuts 94180-41000
Engine Exhaust studs 90179-10070
Engine Valve Adjusting Shims thinnest 13753-74010 2.50
Engine Valve Adjusting Shims 13753-74030 2.55
Engine Valve Adjusting Shims 13753-74050 2.60
Engine Valve Adjusting Shims 13753-74070 2.65
Engine Valve Adjusting Shims 13753-74090 2.70
Engine Valve Adjusting Shims 13753-74110 2.75
Engine Valve Adjusting Shims 13753-74130 2.80
Engine Valve Adjusting Shims size range 13753-74150 2.85
Engine Valve Adjusting Shims 13753-74170 2.90
Engine Valve Adjusting Shims 13753-74190 2.95
Engine Valve Adjusting Shims 13753-74210 3.00
Engine Valve Adjusting Shims 13753-74230 3.05
Engine Valve Adjusting Shims 13753-74250 3.10
Engine Valve Adjusting Shims 13753-74270 3.15
Engine Valve Adjusting Shims 13753-74290 3.20
Engine Valve Adjusting Shims 13753-74310 3.25
Engine Valve Adjusting Shims thickest 13753-74330 3.30
Engine top/front part of the stock airbox with hinge 17505-46100
Engine Bracket (under hood, holds cable over cam cover 78183-14030
Engine Gasket overhaul set 04111-46094
Engine Piston oil squirters TT 15790-88401
Engine power steering pump 44320-14250
Engine Main Engine Harness 82121-14880
Engine Oxygen Sensor Stock Front 89465-19605
Engine Oil Filter Stock Supra Turbo 08922-02011
Engine Oil Filter Lexus V8 90915-20004
Engine K&N Crankcase Vent Breather 62-1000
Engine K&N IAC Breather 62-1360
Engine Air Filter Stock 17801-07020
Engine Fuel Filter - stock 23300-49195
Engine Ford Powerstroke T4 turbo gasket (divided housing) F4TZ6N640B
Engine Oil Filter - us made 08922-02011
Engine Oil Filter - jap made 90915-20004
Engine PCV Valve - TT 12204-46020
Engine PCV Valve - NA 12204-46030
Engine PCV Grommet 90480-18001
Engine Spark Plugs TT ND Platinum 90919-01178
Engine Spark Plugs TT ND iridium 90919-01210
Engine Spark Plugs NA ND iridium 90919-01196
Engine NGK Spark Plugs 3330 or 6097
Engine Dist. Cap (NA) 19101-70020
Engine Dist. Rotor (NA) 19102-46011
Engine Spark Plug Wires (NA) 90919-21521
Engine Drive Belt - serpentine 90916-02310
Engine Drive Belt tensioner (TT 6spd) 16620-46070
Engine Drive Belt tensioner (NA - TT Auto) 16620-0W025
Engine Timing Belt 13568-49036
Engine Cam Seals 90311-40020
Engine Crank Seal 90311-46001
Engine Rear Main Seal 90311-90006
Engine V/C Gasket Intake 11213-46020
Engine V/C Gasket Exhaust 11214-46011
Engine V/C Gasket Exhaust (NA 98) 11214-46030
Engine Fuel Pump TT 23221-46110
Engine Fuel Pump Brkt TT 23206-46160
Engine t-belt idler 13505-46041
Engine t-belt tensioner 13540-46030
Engine Thermostat 90916-03093
Engine Thermostat Gasket 16325-62010
Engine Water Pump TT 16100-49846
Engine Radiator Cap 16401-62100
Engine Alternator TT Auto 27060-46120-84
Engine Alternator TT 6spd 27060-46200-84
Engine Starter 28100-46140-84
Engine Engine Mounts (93.5 - 95.4) 12360-46070
Engine Engine Mounts (95.5-98) 12360-46111
Engine Radiator Assy TT 6spd Alumin type 16400-46420
Engine Radiator Assy TT Auto Alumin type 16400-46430
Engine Short Block Assy TT 11400-49088
Engine Full Gskt Ket - Engine TT 04111-46094
Engine TRD Oil Filter 90915-SP020
Engine Shroud, Fan, No. 1 16711-46160
Fluids & Goo FIPG - Trans. Oil Sealer 00295-01281
Fluids & Goo FIPG - Engine Oil Pan Sealer 00295-00103
Fluids & Goo ATF Type T-4 08886-81015
Fluids & Goo 6-Speed Getrag Oil 08885-01306
Fluids & Goo Antifreeze Toyota Red 00272-1LLAC-01
Fluids & Goo Engine Oil 10w-30 Synthetic
Fluids & Goo Differential Oil 75w-90 Synthetic
Fluids & Goo Differential Oil Redline Shockproof Heavy - Redline 75w-90
Fluids & Goo Disk Brake Caliper Grease 08887-80609
Fluids & Goo Power Steering Fluid ATF or ATF Synthetic
Fluids & Goo Brake Fluid DOT 3 or 4
Fluids & Goo Clutch Fluid DOT 3 or 4
Hoses & Clamps Napa T-Bolt Clamps 2 3/4 - 3 1/16 705-1532
Hoses & Clamps Napa T-Bolt Clamps 3" - 3 5/16" 705-1533
Hoses & Clamps Napa T-Bolt Clamps 3 1/16" - 3 3/8" 705-1525
Hoses & Clamps Napa T-Bolt Clamps 3 1/4" - 3 9/16" 705-1534
Hoses & Clamps EGR Hose 25695-46020
Hoses & Clamps upper radiator hose 16571-46230
Hoses & Clamps Valve cover ventilation hoses (2) 12263-46010 and 12264-46010
Suspension Bilstein Shocks (FRONT) B46-1792
Suspension Bilstein Shocks (REAR) B46-1793
Suspension Brake Rotors - Supra Turbo (FRONT LEFT) 43516-14030
Suspension Brake Rotors - Supra Turbo (FRONT RIGHT) 43512-14200
Suspension Brake Rotors - Supra Turbo (REAR) 42431-14150
Suspension Pads (FRONT) TT 04465-14150
Suspension Front Brake Shims TT 04945-14110
Suspension Front Brake Clips TT 04947-14010
Suspension Front Brake Pad Pins TT 90240-06019
Suspension Pads (REAR) TT 04466-14040
Suspension Rear Brake Shims TT 04946-14030
Suspension Rear Brake Clips TT 04948-14010
Suspension Rear Brake Pad Pins TT 90240-06017
Suspension Brake Cal Kit (FRONT) TT 04479-14140
Suspension Brake Cal Kit (REAR) TT 04479-14130
Suspension Brake Cal Assy (FRONT RIGHT) TT 47730-14260
Suspension Brake Cal Assy (FRONT LEFT) TT 47750-14270
Suspension Brake Cal Assy (REAR RIGHT) TT 47730-14270
Suspension Brake Cal Assy (REAR LEFT) TT 47750-14280
TRD sway bar kit f&r 00602-48800-003
TRD strut tower brace 00602-53607-007
TRD spring/strut kit 00602-48000-008
TRD spring/strut kit 00602-48000-009
TRD SS brake lines 00602-47300-012[discontinued]
TRD oil filter 00642-90915-001
TRD oil cap 00602-12108-003
TRD air filter [oem style] 00642-17801-002
TRD rad cap 00642-16401-003
TRD clutch kit TT 00602-31201-010
TRD gen 2 exhaust cat back TT 00602-17400-016
TRD fuel pressure regulator 00643-23280-000
TRD thermostat 16340-sp020
Other Air Conditioner - dryer/reciever for the a/c 88471-34010
Other Air Conditioner - condensor for the a/c 88460-14310
Other Air Conditioner - reman compressor w/o clutch 88320-14600-84
Other Wiper Blade Assy (RIGHT) 85212-33011
Other Wiper Blade Assy (LEFT) 85222-14610
Other Wiper Blade Assy (REAR) 85242-14020
Other Wiper Blade refill (RIGHT) 85214-YZZB7
Other Wiper Blade refill (LEFT) 85214-YZZB9
Other Wiper Blade refill (REAR) 85214-YZZB6
Other Wiper Blade Arm (RIGHT) 85211-14310
Other Wiper Blade Arm (LEFT) 85221-14310
Other Wiper Blade Arm (REAR) 85241-14020
Other Cylinder Kit, Disc Br 04479-14140
Other Bracket, FR Bumper E 52114-14100
FILTERS:
air filter-#17801-07020
fuel filter-#23300-49195
oil filter-#90915-20004 [jap made]
pcv valve-#12204-46020[TT]
pcv valve-#12204-46030 [NA]
pcv grommet-#90480-18001
FLUIDS:
automatic-#08886-81015 type-t-iv
getrag 6spd-#08885-01306 v160
antifreeze-#00272-1LLAC-01 Toyota Red
engine oil- 5w30 or 10w30
differental oil- 75w-90 or equilivent
disk brake grease-#08887-80609
WIPER PARTS:
blade assy rh-#85212-33011
blade assy lh-#85222-14610 [also works on rh side]
blade assy rear-#85242-14020
refill frt rh-#85214-YZZB7
refill frt lh-#85214-YZZB9
refill rear-#85214-YZZB6
arm rh-#85211-14310
arm lh-#85221-14310
arm rear-#85241-14020
TUNE UP PARTS:
plugs-#90919-01178 [TT] ND platinum
plugs-#90919-01210 [TT] ND iridium
plugs-#90919-01168 [NA] ND platinum
plugs ngk for bpu-#3330
dist cap-#19101-70020 [NA]
dist rotor-#19102-46011 [NA]
wires-#90919-21521 [NA]
coil-#90919-02205 [TT]
coil-#90919-02207 [NA 93.5-97]
coil-#90919-02216 [NA 98]
coil elec. plug repair-#90980-11246
BELTS:
drive belt-#90916-02310[serpentine]
drive belt tensioner-#16620-46070 [TT 6spd]
drive belt tensioner-#16620-0W025 [NA all /TT auto]
timing belt-#13568-49036
BRAKES:
frt pads-#04465-14150 [TT for 4pot calipers]
frt shims-#04945-14110[TT]
frt clips-#04947-14010 [TT]
frt pad pins-#90240-06019[TT]
rear pads-#04466-14040 [TT]
rear shims-#04946-14030 [TT]
rear clips-#04948-14010 [TT]
rear pad pins-#90240-06017 [TT]
frt rotor rh-#43512-14200 [TT]
frt rotor lh-#43516-14030 [TT]
rear rotors-#42431-14150 [TT]
cal kit frt-#04479-14140 [TT]
cal kit rear-#04479-14130 [TT]
cal assy frt rh-#47730-14260 [TT]
cal assy frt lh-#47750-14270 [TT]
cal assy rear rh-#47730-14270 [TT]
cal assy rear lh-#47750-14280 [TT]
frt pads-#04465-14081 [NA and 2pot caliper TT]
frt shims-#04945-14010 [NA]
frt clips-#04947-24030 [NA]
frt cal pins-#47715-24010 [NA]
rear pads-#04466-30030 [NA]
rear shims-#04946-24010 [NA]
rear clips-#04948-50010 [NA]
rear cal pins main-#47715-06030 [NA]
rear cal pins sub-#47715-06020 [NA]
frt rotors-#43512-14190 [NA]
rear rotors-#42431-30140 [NA 93.5-95]
rear rotors-#42431-30240 [NA 96-98]
cal kit frt-#04479-14120 [NA]
cal kit rear-#04479-24030 [NA]
cal assy frt rh-#47730-24082 [NA 93.5-94]
cal assy frt lh-#47750-24082 [NA 93.5-94]
cal assy frt rh-#47730-14281-84 [NA 95-98]
cal assy frt lh-#47750-14291-84 [NA 95-98]
cal assy rear rh-#47730-14240-84 [NA]
cal assy rear lh-#47750-14240-84 [NA]
WHEEL BEARINGS/SEALS
frt axle hub-#43502-30140
frt wheel brg-#90903-63006-77
frt wheel seal-#90311-50008
rear axle hub-#42301-30030
rear wheel brg-#90369-43005-77
rear seal inner-#90311-63001
rear seal outer-#90311-57001
CLUTCH PARTS:
pilot brg-#90363-12002-77 [TT-NA]
t/o brg-#90903-63001 [TT]
t/o brg-#31230-22100 [NA]
clutch cover-#31210-14170-84 [TT]
clutch cover-#31210-30261-84 [NA]
clutch disc-#31250-14190 [TT]
clutch disc-#31250-30391-84 [NA]
clutch master-#31410-14310
clutch slave-#31470-22120 [NA]
clutch slave-#31470-14060 [TT]
clutch master kit-#04311-12110
clutch slave kit-#04313-14020 [TT]
clutch slave kit-#04313-17010 [NA 93.5-96.5]
clutch slave kit-#04313-22030 [NA 96.6-98]
clutch fork-#31204-14060 [TT 6spd]
clutch fork-#31204-22050 [NA 5spd]
ENGINE PARTS:
02 sensor-#89465-19605
cam seals-#90311-40020
crank seal-#90311-46001
rear main seal-#90311-90006
v/c gskt intake-#11213-46020
v/c gskt exhaust-#11214-46011
v/c gskt exhaust-#11214-46030 [NA 98]
silicone gasket sealer-#00295-00102 [the black stuff in a tube]
pcv hose frt v/c-#12264-46010 [TT]
pcv hose rear v/c-#12263-46010 [TT]
fuel pump-#23221-46070 [NA 93.5-97]
fuel pump-#23221-50060 [NA 98]
fuel pump-#23221-46110 [TT]
fuel pump brkt-#23206-46160 [TT]
fuel pump brkt-#23206-46140 [NA]
t-belt ilder-#13505-46041
t-belt tensioner-#13540-46030
t/stat-#90916-03093
t/stat gskt#16325-62010
w/pump-#16100-49837 [NA]
w/pump-#16100-49846 [TT]
rad cap-#16401-62100
alternator-#27060-46200-84 [TT 6spd]
alternator-#27060-46120-84 [TT auto]
alternator-#27060-46190-84 [NA 93.5-95.5]
alternator-#27060-46050-84 [NA 95.6-98]
starter-#28100-46140-84
engine mounts-#12360-46070[93.5-95.4]
engine mounts-#12360-46111[95.5-98 improved design]
trans mount-#12371-46110 [TT 6spd]
trans mount-#12371-46120 [TT auto]
trans mount-# 12371-46090[NA 5spd]
trans mount-#12371-46020 [NA auto]
radiator assy-#16400-46420 [TT 6spd Alumin.type]
radiator assy-#16400-46430 [TT auto alumin.type]
radiator assy-#16400-46290 [NA 5spd]
radiator assy-#16400-46300 [NA auto]
short block assy-#11400-49088 [TT]
full gskt kit engine-#04111-46094 [TT]
BODY PARTS:
hatch stay rh-#68950-19895 [w/spoiler]
hatch stay lh-#68960-19585 [w/spoiler]
hatch rubber stopper-#67293-14051[stops the squeak]
screws for above 2ea-#90159-50116
targa roof-#63201-14060
targa mld rh-#63217-14030-C0
targa mld lh-#63218-14020-C0
targa w/strip rh-#62383-14030
targa w/strip lh-#62384-14030
targa headliner-#63312-14050-C0
targa bolts frt-#90901-09004
targa bolt /brkt rear rh#63240-14090[2pc brkt w/bolt]
targa bolt/ brkt rear lh#63240-14060 [2pc brkt w/bolt]
targa ctr.lock assy-#63203-14100
HELICOIL KIT FOR TARGA BOLTS-#5546.6 [6mm x 1.0]
turbo spoiler rear-#76085-14909
frt glass mld-#75533-14190
back glass mld-#75573-14210
floor carpet-#58510-1B171-A0 [ stick/ivory]
floor carpet-#58510-1B171-C0 [stick/black]
floor carpet-#58510-1B181-A0 [auto/ivory]
floor carpet-#58510-1B181-C0 [auto/black]
rear lisc.plate nuts-#52121-24020
tonneau cover trunk-#64910-14060-C0
power antenna-#86300-14411
power antenna mast only-#86337-14411[chrome only]
ash tray-#74102-14130 [93.5-96]
ash tray-#74102-14140 [97-98]
ACCESSORIES:
front end mask-#00218-14930
mudguards frt-#76095-14010
wheel locks-#00276-14930
floor mats blk/ivory logo-#00200-14930-08
floor mats blk/silver logo-#00200-14930-13
floor mats blk/SE logo-#00200-14950-01 [discontinued]
EMBLEMS:
gold NA kit -#00211-14950[no "turbo"logo]{discontinued}
gold TT kit -#00211-14970 [w/"turbo" logo]{discontinued}
gold SE kit-#00211-14954 {discontinued}
gold SE logo only-#00211-14953 {discontinued}
gold ctr cap logo-#00211-00951
gold ant. nut-#00577-35950
gold "logo"frt-#00211-14956
gold "toyota"-#00211-14951
gold "supra"-#00211-14952
gold "logo"rear-#00211-14957
15th anniv.logos-#00211-14971-01 blk
15th anniv.logos-#00211-14971-28 silver
SE side stripes rh-#00211-4R951
SE side stripes lh-#00211-4L951
"turbo"logo -#00016-23940{small brushed Aluminium w/black letters used by Toyota Southeast Distributors.94-95?TT}
frt cover "logo" grey-#75314-14010
tailgate "toyota"grey-#75441-14190
tailgate "logo" grey-#75471-14010
tailgate "supra" grey-#75442-14280[93.5-96 TT all NA]
tailgate "supra turbo" grey-#75443-14180[97-98 TT]
trd 3pack logo-#00602-42601-EMB[carbon fiber style 1"x2.75" "toyota racing development"red letters "TRD" chrome large letters]
TRD SPORT PARTS:
trd sway bar kit f&r-# 00602-48800-003
trd strut tower brace-#00602-53607-007
trd spring/strut kit-#00602-48000-008 [NA][discontinued]
trd spring/strut kit-#00602-48000-009 [TT] [discontinued]
trd SS brake lines-#00602-47300-012[discontinued]
trd oil filter-#00642-90915-001
trd oil cap-#00602-12108-003
trd air filter-#00642-17801-002[oem style]
trd rad cap-#00642-16401-003
trd clutch kit-#00602-31201-010 [TT]
trd gen 2 exhaust cat back-#00602-17400-016 [TT]
trd fuel pressure regulator-#00643-23280-000
trd brake pads-#00602,00643-XXXXX-XX [all discontinued]
trd 10,000 rpm tach-#[all discontinued]
DRIVETRAIN:
getrag 6spd assy-#33030-0W212
silicone trans pan sealer-#00295-01281 [orange stuff]
atm screen filter-#35330-30011 [NA 93.5-97]
atm screen filter-#35330-50010 [TT /NA 98]
drive shaft-#37100-14810 [TT 6spd]
drive shaft-#37100-14820 [TT auto]
rear diff pinion seal-#90311-50018 [6spd]
rear diff pinion seal-#90311-44005[ TT auto-NA all]
rear diff axle seals-#90311-45013 [6spd]
rear diff axle seals-#90311-47008 [auto all/NA 5spd]
input shaft seal-#90080-31037[TT 6spd]
output shaft seal-#90080-31029[TT 6spd]
shift rod case seal-#90080-31032[TT 6spd]
OIL PRESSURE SENSOR MOD:
union bolt-#90401-19008
gasket-#90430-20016
o ring-#90301-68005
EXTERIOR LIGHTING:
3rd stop lamp-#81570-14060[93.5-94]
3rd stop lamp-#81570-14061[95-98]
head lamp lh-#81151-1B241 [98 style grey no bulbs]
head lamp rh-#81111-1B241 [98 style grey no bulbs]
tail lamp lh-#81561-14700 [98 style grey no bulbs]
tail lamp rh-#81551-14700 [98 style grey no bulbs]
t/s lamp frt rh-#81510-80086 [97-98 clear assy w/bulbs]
t/s lamp frt lh-#81520-80086 [97-98 clear assy w/bulbs]
t/s frt harness -#81515-14390[97-98 pig tail for aftermarket lamps]
turn signal/hazzard flasher-#81980-12070
indicator-#81730-20220 [93.5-96 style indicators in clear]part is actually for the 2003 corolla but perfect fit for supra
EXHAUST HARDWARE:
lock nuts-#90179-08059 [8mm w/washer for 02 studs/ misc]
lock nuts-#90179-10070 [10mm w/washer for studs / misc]
bolts-#90105-10023 [ 10mm w/washer for exh pipes]
nuts-#94180-41000 [10mm w/washer for exh pipes]
studs-#90179-10070 [10mm for most mainfolds/exhaust]
INSTRUMENT PANEL BEZELS 97/98
part# 55410-14530 ctr upper
part# 55404-14570 lh dash
part# 55420-14060 speedo bezel
part# 55405-14170 radio/hvac panel
part# 58804-14100 6spd shift bezel
part# 58804-14110 atm shift bezel
part#74232-14121 lh door switch bezel
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
seen the list before somewhere..
but i just go to the toyota dealer for the part #'s...
mainly because they will always have up to date #'s not out of date ones heh
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
Some of this list isn't bad, but a lot of it is out of date and discontinued. The dealer will have the most up to date information. If they are incompetent or whatever, just talk with one of the people online.
Sometimes things change with years, etc, so just a list isn't always the best way to make sure you're getting the right part.
In any case, it doesn't really hurt, so good work. I've seen list list elsewhere as well.
Jeff
