2jz na-t vaccum?
tomsupra8683
82gts7mgte
Mar 31, 2007
105
puyallup
I recently did a 2jzge na-t swap into my celica and im only getting -10lbs vaccum at idle is this normal?I could only find a couple boost leaks and they were small it was just some of the vaccum plugs i used.My 7mgte always had -20 under vaccum so i though the 2jz would have the same.
te72
Classifieds Moderator
6,611
7
WHYoming
What cams are you running, and what sort of elevation are you at? Given that your old engine created more vacuum, I would think that you may have a leak somewhere...
tomsupra8683
82gts7mgte
Mar 31, 2007
105
puyallup
Im at sea level.Its a stock 2jzge out of a 96 lexus is300.I must have more leaks ill keep searching.The metal gaskets for the intake maybe the issue i didnt replace them cause they looked good.
