2JZ-GE >> MKIII ?
iamshawn
codename: HENRO
Nov 2, 2005
74
Houston
So i have a 90 MKIII turbo which i'm building an engine for (very slow progress)
Stumbled on a 1995 SC-300 front clip.
would it be simple enough just to take whatever under the hood of the SC300 + the wiring and the ecu from it and run it with my 340E from my supra mounted to the 2JZ bell housing ? Eventually i will need boost.. So turbo the GE (NA-T) or can i go 1.5 JZ O_O... are the blocks GE and the GTE compatible ? meaning if i want to put GTE head with the turbos on the block later on would it match up ? Wiring and etc will have to be made but yah.. just the mechanical things i'm pondering about.
Or should i just keep building my 7M ^___~
