272's cams on a 2jz-ge
TLDriver
67
Ventura, California
Hey guys, the plans are to add some 272's cams in my non vvti GE head. I know retainers and shims are needed for this, what I am debating is do I need to upgrade the valve stems too?
What happens if the stock valves are used? Just want some input before doing anything. Thanks in advance.
-Eddie
RacerXJ220
Interdimensional
Abalama
You don't really NEED springs and retainers with 272's. Good to have. I have never, ever heard of a valve floating on any 2JZ with stock springs and retainers with most 272's (9.3mm lift).
Ferrea stem seals are cheaper than OEM IIRC.
I would definitely swap the stem seals out while you have the head apart.
Good luck.
TLDriver
67
Ventura, California
Good luck.
Cool thanks for the input. I was just wondering if there was real need to swap them out.
