1st time at the track
bokyo1
4
texas
Well finally took my supra out to the local 1/8 mile track. First run was a 10.09 @72.91 with a 2.54 60'. Second was a 9.87 @ 73.28 with a 2.43 60'. Do these times sound about right for a pretty much bone stock turbo mk3? The only modes to the car are an upgraded fmic, and hard upper pipes. Everything else is stock.
dbsupra90
toonar
indiucky
mid 9's is about right. yours arent too far off, its the 60' that is killing you. work on your launch, and consider getting some drag radials. if you get that down to 2.0 range its going to make a huge difference in your et.
keep at it!
CampbellsChunkySoupra
best be eating your soup!
Jan 28, 2007
620
Norwalk, IA
www.dragsource.net
id start replacing some things before id even race it.
that mid to high 9 sounds about right. the launch is where its at. my buddies built 1g dsm was running high 9's but had crazy high trap speeds. he just cant launch his fwd car with street tires on it.
get a 3" turbo back exhaust, a boost controller, a nice air filter, and some drag radials. u'll be set!
