1jzgte ecu help
twistedshadows
28
miami
my friend had a 1jz swap done on his mk3 everything was good for about a month and a half then the car would act up time to time i checked all the wiring and could find nothing wrong
all sensors are good so i took apart the ecu excepting to see a burned ic but it turns out that only a resistor is burnt i cant see the middle band on it and resistors are so cheap i cant let my friend get a new ecu until i replace this resistor its r378 it has 2 red bands at 1 end and a gold at the other but i cant see the middle (multiplier band) if any 1 has a 1jz ecu they can take apart and check for me that would be GREAT or can point me at any info at all
thanks
joe
