1jz wiring on MA70
AZN MK3
341
Now in the U.S.
ok let me get this straight... the plugs from my 1jz harness doesnt not fit my plugs on my car... so does that mean i have to cut and solder the wires together... because from the looks of things from the website http://1jz-gte.us... it shows how to connect the wires and the plugs do look different.. well to get in more detail im talkin about the IH1, IG1, and IH2 plugs... the dont match im thinking its because my 1jz harness is off of a soar car and im trying to use it on a supra... im i wrong or what??? im really stomped... i'll post pics later.... tomorrow when its day time so i'll be a better pic... i really need help... trying to get the car running... and i need yall's help... thanks
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
AZN MK3 said:
ok... thanks... well how will i know if i have a soarer harness or not.. i really would like to see pics of the harness to make sure...
Easiest way is to look at the ECU plugs. Here are the pictures of the plugs. Just look at these and match the shape of the plugs and you'll have your answer.
First one is the JZA70 (Supra) pinouts
Second is the JZZ30 (Soarer) pinouts
AZN MK3
341
Now in the U.S.
no what i have a problem with is the other plugs like the IH1&2 IG1 and all... all the plugs to the ecu work and plug in but not the other plugs...
its the plugs from this site...http://1jz-gte.us/documents/SubDocs4/Connector IDs.pdf... all of those connectors... is what i have a problem with...
AZN MK3
341
Now in the U.S.
AF1JZ said:
oh, ok. It isn't going to be plug and play. You will have to cut and splice. I don't know how to wire the supra harness. Sorry. G/L
damn that what i wasnt hoping for... do you happen to know if the wiring from the site http://1jz-gte.us/ is accurate... beacause i do see that its kinda different but i dont know for sure...
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Some of the colors are different because of the year of the supra. Get ahold of bigaaron for some advice. He can probably point you in the right direction since he is the expert at the swaps.
AZN MK3
341
Now in the U.S.
TaSe said:
aaron did my jumper harness for under 150 and it looks flawless.... i will see how well it works when i plug it in. i have no doubts tho.
jumper harness... just so that the dash cluster and stuff would work??? cuz thats my problem....
AZN MK3
341
Now in the U.S.
MAN... ok im really stumped..... what is ppl talkin about i can get a jumper harness so that my other plugs not meaning the ecu plugs but the other plugs under the glove box.... or do i just rewire them up or so???
