1JZ weight
s14eva1
SFL
I've search but could not find accurate info on the exact weight of a 1JZ motor....anyone know those specs?
Dirgle
Conjurer of Boost
Pauma Valley, CA
s14eva1 said:
well I'll try and ask him...I'm hopping its under 500lbs
Thats hoping for a lot, it has an iron block, which doesn't help the weight factor. If I had to guess, and this is only a GUESS, I'd say closer to 800lbs.
OneJoeZee
Retired Post Whore
aboard the Argama
Ric said:
Smaller motor, its only 2.5 liters ::dead horse::
So? It's not like it's you lost 2 cylinders or something. I don't think the difference in the crank and rods really would make it too much lighter or enough to raise your car up an inch.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
Ric said:
It was a joke... I thought someone would LOL?
Im not exactly sure why, but it did make the front raise a bit due to being lighter.
It's because Homer's wife isn't in it....now that's a joke...LOL.:biglaugh:
s14eva1
SFL
kikwear002 said:
my freight bill was 625 lbs with trans and ecu
thats what I thought....the tranny alone weighs around 120-125 lbs
so motor alone without turbo's(in my case) should be under 500lbs
ToyoHabu
261
Huntsville, Alabama, United States
how different is this motor? the block uses some of the same accessories , I believe the outer dimensions are the same except height of the block. the head is very similar dimensionally. I do not see much reason for more than 1 - 2 percent difference on the long block. The main weight difference here would be when you are comparing a turbo to non turbo engine. I would think 1jzgte almost equal to 2jzgte in weight. 1jzgte should be what ? 40 70 lbs heavier than the 2jzge?
Adrian98
182
orange county
I have to agree with joe and ToyoHabu.
I've taken apart 1kz and they are so much like the 2 it's scary. at absolute most, with the smaller turbos and shorter crank and maybe if there's a few pounds off the head and intake i think at MOST it could only be 40-50 lbs lighter than a 2j
