1JZ timing question
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
Do you have a tuner? I had stinger, and then took a step back and installed a stock ecu and Map ECU 2. Both are great systems, but my car runs FAR better on the map ecu 2 than it did on the stinger, I only had my high throttle stuff tuned professionally and the rest was by me. If you don't have a professional to tune it (not just for full throttle... thats the easy part IMO) then you're probably better off with the Map ECU 2 as well.
chuckmuska2005
265
canton
I have a tuner, I had been looking into the EMU, I don't know too much about Stinger or the Map2 setup. I'm running a neo for right now looking at getting the car back to the twin setup( turbo broke when I was clocking it and I need it outta my parents garage, LOL). I'm looking to later down the road, throw on my 680cc injectors and dual feed line with my new single turbo(that still needs to be purchased) and just wondered what I could use to help timing issues which I'm sure there are to be.
