1jz single start up???????
chuckmuska2005
265
canton
I finished my 1jz single turbo build and am not sure how I need to go about the start up procedure as to actually turning the engine over. I am running the Apexi Neo and the aem Uego wideband. I know how to run throught the start up procedure on the Neo. What do I do about boost? I have the wastegate set at 10psi. What do I need to do? What am I able to do about the tune?:1zhelp:
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
just make sure you prime the motor so it has oil through it completely and make sure you have your settings on the afc right. then i would start it after you've checked everything to make sure its ok. make sure your waste gate is running off the spring and not something like 20 psi. you wont be able to do anything about he tune till you get the car idling. when the car is idling you can pull fuel out if it needs it then once everything is okay at idle you can start tunning the part throttle and WOT.
