1jz radiator
chuckmuska2005
265
canton
I just wasted my radiator, the fan smacked a hole in it. So my idea is to go with an aluminum radiator and e-fans. I've started to wonder if a 2jz radiator will go into a mkiii with a 1j swap. The reason I'm asking is because all the radiators I have found on titan motorsports and ebay are all a boxed style for the mkiii and the radiators for the mkiv have the little half cup on the end of the radiator for the mounting brackets.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
i dont think the A80 radiator will fit the A70 chassis, could be wrong tho
what radiator are you running right now, and are you runing the TT fan and clutch?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
they mount different. efans are not exactly an upgrade... they are a downgrade.
any 7m radiator will be fine. if you want to do it cheap buy a 240sx one off ebay and get crafty with the mounting points.
chuckmuska2005
265
canton
So I looked up the 240sx radiators and they look like they will work but will the bottom mounting pieces drop in the hoes where the factory radiator goes?
