1JZ Power steering lines and adapting 7m oil pressure sensor
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Can I use both power steering lines from a mk4 supra to use on my 1jz mk3 supra? Where to get low pressure line?
How do I adapt the 7m oil pressure sensor? Do I need an fitting line and adapter fitting to a 7m ops to use it?
You can use a mk4 ps pressure hose. Return is just 3/8ths oil hose. Nothing special.
You use the dm oil pressure hose for that.
destrux
1,183
10
PA
If you want to save about $50 get a power steering pressure hose for a 94 Maxima. I used it on mine and it fits perfectly. It also eliminates the power steering idle up valve, which isn't needed anyway.
Mk3*Supra
333
Ohio
driftmotion has SS lines for PS.. then 3/8 line like said previously
and get the oil pressure adapter from them as well
