1JZ Oil Pan Removal
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
How do you remove the lower oil pan with the engine in the car? Do you have to lower the x-member as per the TSRM or is there another way?
fstlane88
Single time!!
South FL
No it's doable with the engine in the car but not fun...They're all 10mm bolts and all are easy to get except the last 3 or 4.
You'll have to loosen and remove the nuts holding the motor mounts in and either jack up the front of the motor or use a hoist and raise it up to get to the last like 3 bolts at the front of the pan. I used my floor jack with blocks of wood on it, make sure they are skinny enough to clear the sway bar and crossmember but make contact with the upper pan just behind the crank pulley.
I've had to do it twice and am going to have to do it again b/c I broke the last fucking bolt, BE CAREFUL with them, I broke it not even trying to tighten it down that hard with a 1/4" ratchet.
Also the last time I did this I jacked the motor up so far the mounts came out of their saddles and I had to use a hoist to put the motor back in properly no biggie but if you don't know someone with a hoist, it's something keep in mind and watch for.
If you do it, and come up with some easier ways to do it, let me know I'm not really looking forward to doing again.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
like ^^ said, its doable in the car but holy crap its annoying, i had to undo the mounts and lift the engine to get my hands in there to get the front few bolts
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
IT'S NOT THAT BAD!
Yes, you need to undo your motor mounts, and raise your motor up a few inches (or as far as it will go), but it's not THAT bad.
You CAN actually do it without raising the motor, but i's way more trouble than it's worth. Raise it up, and be happy.
You can actually remove the ENTIRE oil pan this way. I did the whole pan in about 2 hours.
fstlane88
Single time!!
South FL
As in the upper and lower...really, damn I was looking at that last time I under there thinking at least I don't have to pull the upper fucking pan off.
935motorsports
San Diego, CA
What they said... Jack up the motor, undo the lower motor mount nuts.
What you really need is a 1/4" 10mm with the universal joint built in. I borrowed that from the shop next door and it made the job a snap.
We did one for a customer, only charged about $100 labor out the door and I was pleased with the time spent.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
thanks for the info gonna give it a try this w/e.
Kosh
144
Edmonton
Hey, i just noticed last night while pulling my turbos that my oil pan is dented pretty good and needs replaced. Where can i get a new one?
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
i got the lower oil pan out with the motor in the car took about 15 min its not hard at all i didnt ever need to lift the motor up.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
so how did you do it? care to explain?
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
is there a difference with more room around the subframe on the SC300? when i did this on my car, id need the hands of a 10 year old to get into the small spaces
OneJoeZee
Retired Post Whore
aboard the Argama
I think so... The difference between an SC engine bay and an A70 engine bay is like a swimming pool to a bath tub.:biglaugh:
annoyingrob
Boosted member
Jul 5, 2006
2,304
Dealership. 1JZ and 2JZ share the same pan. You'll probably just need the lower part.
Might be cheaper to just hammer the pan out though.
Kosh
144
Edmonton
well I have my turbo's off my car right now and i'm going to change the oil before i put them back on anyway. U think i should just hammer it out? Does it really matter the shape as long as it clears the crank?
