so i just swapped my 1jz and i'm not getting spark. the wierd thing is that when i first turned the car over it started right up. so i turned it off to check a few things and the car wont start, it's getting fuel but no spark. i'm told that the coil packs are supposed to have 12v on both wires i only get 12v on one wire (the one from the harness 12v not from the ignitor) the wire from the ignitor has no voltage. i know i'm getting fuel because after a while of fustarted(lol) cranking the car got flooded with fuel and wouldnt turn. i pumped out all the fuel and still no go. could my ignitor be messed up? or is it more likely that i have a bad ground? my motor is not really ground to the chassis although the harness is. would that cause it not to have spark? any help is appresiated thanks!!
