1jz-gte head studs
shaggyskadude13
AAARRRGGGHH!!!!!
May 16, 2007
Rockledge, Florida
I was wondering how much boost you can run through a stock 1jz. Or what companies make head studs for the 1j. If i get a metal head gasket will that help me run more boost with out chancing a blown head gasket?
tissimo
Stock is boring :(
Melbourne, FL
500-600 has been done on a bone stock 1j with no problems..
I wouldn't worry about going to studs till around 700 or so.. i THINK 2j stuff is the same, so arp 2j studs would work..
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
Tissmo has the idea and also so you know the 1J Stock has a Metal HG, If you want i can sell you a brand new Stock MHG. :) you'll have lots of other things to worry about to get up in the numbers.
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
It's not a 7M.
You'll see a good 600whp before you blow a HG and that's probably just due to old age. ARP studs from a 2JZGTE work just fine. Also 2JZGTE headgaskets work just fine. The best headgasket is OEM.
