1JZ free hp mods
Blksupra1jzed
153
Raleigh, NC
I did a search and couldn't find a thread like this, I hope it wasn't just user error. My Dad ran across a thread like this in a 300ZX forum and he got several good tips for his car...
So..what kinda stuff is out there that you can tweak or modify at little or no cost and also it be safe to do?
OneJoeZee
Retired Post Whore
aboard the Argama
you shimmed your 1j wastegates? How's that working out for you.
If my engine wasnt already in, and it wasnt a freakin bitch to get to the rear turbo i might try it.
when I said jew boost, I meant a bleeder T mod though :]
935motorsports
San Diego, CA
Just open her up. There is no need to shim the wastegates. With full exhaust and intake mods, you should hit 14-15 anyway.
After that, ECU and cams are on order, but those are expensive options. Finally get the intake charge as COLD as possible. That means cold air intake and/or IC upgrade. Raising boost can be a NO NO without cooling the charge, and can quickly lead you to a "I need to replace my engine" post.
OneJoeZee
Retired Post Whore
aboard the Argama
very true
ask me how I know :rofl:
yeah, youre right about the non issue on the shims. I wasn't thinking clearly. alot of cars free'd up exhaust and intake will hit fuel cut sometimes. I haven't had that issue, yet luckily
Blksupra1jzed
153
Raleigh, NC
Yeah it's a bitch to get to but you do it before you put the motor in. It's working fine. I just don't wanna test my own luck with the 1 bar of pressure threshold the exhaust side has. I have an HKS intake I believe that is as "cold air" as it gets. I may take the spare hood I have from the clip and see if I can find a conservative yet functional scoop that does NOT stick up far at all and mount it behind the headlight over the intake. I just haven't looked into that yet. I am only thinking maybe an inch or so tall and a few inches deep and about as wide as the headlight.
OneJoeZee
Retired Post Whore
aboard the Argama
if you just have the HKS kit, its not cold air exactly.
cold air would be running the filter behind your foglight out of the engine bay or something.
jbsupra89t
Achieving Balance...
NJ
If not behind the foglight, fashion yourself a heat shield for the intake, that'll help too, if you can get a pretty tight seal to the hood. I think supraracer01 did that...
-J
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
most common mod ive seen is taking something like 4" pvc or dryer hose and running air from the front foglight housings into the intake
edit: dont use the rear foglight housings...damn, i just got owned by me.
