1jz engine no ecu no harness, what to do
RPSil13
464
Anaheim, CA
if i have a 1 jz engine, but it comes w/ no harness or ecu, what is the best method to go about getting the engine running, could i just go stand alone or would i still need a 1jz harness, or is the 2jz harness compatible, sorry if these are stupid questions but i could figure out what to search to bring up what i was looking for
thanks
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
give aaron a call at driftmotion. you could probably use a standalone but it might be hard without a base to work from. make sure it works with the 1j ecu and then go from there.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
you could probably find an Aristo Harness and Ecu from a 2JZ and run it easier than finding a 1JZ harness.
a few guys on here have gone that route
RPSil13
464
Anaheim, CA
i guess ill give aaron a call tomorrow morning, also does anyone have a link to people running a 1jz off of a 2jz harness
thanks
dinhnerz
52
Cali
Search around forums, usually people sell their 1jz wiring harness. Also check ebay, I believe there is a 1jz harness and a couple of ecu on ebay right now.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
There is a 1jz ECU online right now along with 2jz ecu's. I will be buying a motor in a couple days, and I am going to make sure it has a harness igniter, and ecu.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Agreed with BigZav. Nothing fancy in the wiring either and the Aristo eciu maybe more reliable too since the 1jz ones seems to blow caps quite a bit recently.
I sold my harness setup to run the Aristo ecu and harness for my 1jz.
Blksupra1jzed
153
Raleigh, NC
Fletch124;1145632 said:
Could always try Jeff Watson at Champion Toyota. (713)-943-7010
+1. Been dealing with him for almost 4 years now. Extremely helpful with parts and great with prices as well.
Caps as in capacitors? Nothing has failed me yet but always open to the heads up...
