1jz does not run
bongo
12
montreal,qc
so i was out crusing last week when my car just shut off at a red light, had to get it towed home. its cranks starts then dies after 2 seconds, fuel pump is priming i have spark, i clamped my return line from my regulator and blocked the vacuum and it started and idled for around 10 seconds then it died again. i tried several times after that to start it the same way and it only ran twice. now my next step will be to do a fuel pressure test but does anyone have any other ideas for what it could be. btw ecu was sent to MINES from previous owner.
te72
Classifieds Moderator
6,622
9
WHYoming
How's your harness wiring to the battery? I foolishly ran my car for a few years without a battery tie down in place. From all the cornering and spirited driving, the battery had eventually moved around so much that I was left with TWO strands of the harness to battery connection. Was cutting out intermittently and wouldn't start with anything resembling ease.
Unfortunately this was 200 miles from home. Fortunately it was during the middle of the day, so a trip to the auto parts store for some crimps, connections, and wire saved the day. :)
bongo
12
montreal,qc
from what i remember my harness looks ok but i will double check when i have . im gonna do a fuel pressure test cause im pretty convinced its something to do with fuel unless anyone has any other ideas.
bongo
12
montreal,qc
so i tried to look for codes with the paper clip style but that didnt work as well so my manager is gonna make a special jumper tomorrow but any other help would be appreciated as well and as soon as i check for codes i will update as well.
bongo
12
montreal,qc
So it seems that my diagnostic box is not conected and I had no luck fitting a fuel pressure tester in there so now I'm just trying tofigure out what I can do to test the pressure from another spot. Does anyone have any ideas? that would be great.
525gte
450
hoquiam
What harness do u have. Mine was out of a chaser and the wires for the ck codes were cut. I have mine running to a toggle switch. . U just have to locate the wires. U may be able to trac them back to ecu and ck codes that way
mkiiichip
1,434
WI
Yep, just ground TE1 at the ecu. But that only helps if the light is hooked up.
OP, does the "check engine light" come on, with the key on?
bongo
12
montreal,qc
my harness is from a supra front clip. is there a way to check if there conected properly without having to go throught the entire harness?
scottiedawg66
Bay Area Ca
you can just literally ground the TE1 wire and it should start to flash the codes. probably your best bet so you do not have to go through the entire harness to find the wire. I would just put a toggle switch in there as stated above.
bongo
12
montreal,qc
thanks for the info guys sorry i havent posted much i work alot and since its winter so i have 6 months to work on my minor problems. and the reason i didnt wanna mess with my ecu since its located under my radio but i had no choice and removed the center console so im gonna test it hopefully tomorrow
bongo
12
montreal,qc
hey guys been a while since i updated. around two weeks ago i had a chance to check out my ecu only to find out that two capacitors leaked and damaged my motherboard pretty bad so i have decided that im gonna get a megasquirt ecu. does anyone have any reviews on megasquirt just to know before spending money on something that wont work good.
