18 Ways to Find Canon printer Offline Issue - How to Fix
markscull
Seeing a Canon Printer Offline +1-801-878-6858 error on your Windows or Mac system can be frustrating, especially when you need to print something urgently. Fortunately, this is a common problem that can usually be resolved with a few simple troubleshooting steps. Whether your Canon printer says offline +1-801-878-6858 or doesn’t respond to print commands, this guide will walk you through the causes and the best ways to fix the issue.
Click Here For Live Chat With Canon Printer Support
Why Does Your Canon Printer Show as Offline?​
When a Canon printer appears offline +1-801-878-6858, it means your computer can’t communicate with it properly. Several factors can cause this issue:
  • Loose or faulty USB or network connections
  • Printer is turned off or in sleep mode
  • Incorrect printer settings (set to offline mode)
  • Outdated or corrupt printer drivers
  • Network connectivity issues (for wireless printers)
  • Print spooler service not running
  • Conflicts from multiple printer installations
Identifying the cause is key to solving the Canon printer offline issue permanently.
Step-by-Step Guide to Fix Canon Printer Offline Error​
1. Restart Your Devices
Start with a simple restart. Turn off your Canon printer, unplug it for 30 seconds, then plug it back in and power it on. Do the same for your computer and router (if using Wi-Fi). A fresh reboot can reset internal settings that might be causing the issue.
2. Check Physical Connections
If you're using a USB cable, make sure it’s securely connected to both the printer and your computer. Try switching to a different USB port. If you’re using a wireless Canon printer +1-801-878-6858, ensure it is connected to the same Wi-Fi network as your computer.
You can print a network configuration page from the printer’s settings to confirm the wireless connection.
3. Set Canon as the Default Printer
Sometimes the system selects a virtual printer like “Microsoft Print to PDF” instead of your actual Canon device.
For Windows:​
  • Go to Control Panel > Devices and Printers
  • Right-click on your Canon printer and select Set as default printer
For Mac:​
  • Go to System Settings > Printers & Scanners
  • Click on your Canon printer and set it as Default
4. Disable “Use Printer Offline” Mode
This is one of the most common reasons a Canon printer shows offline.
Windows:​
  • Go to Devices and Printers
  • Right-click your Canon printer > See what’s printing
  • In the new window, click Printer and uncheck Use Printer Offline
This will immediately bring the printer online if that setting was enabled.
5. Clear the Print Queue
A stuck print job can freeze communication between your PC and the printer
  • Open Devices and Printers
  • Right-click on your Canon printer > See what’s printing
  • Cancel all documents in the queue
  • Restart your printer and try printing again
6. Run the Printer Troubleshooter
On Windows, the built-in troubleshooter can automatically detect and fix issues.
  • Go to Settings > Update & Security > Troubleshoot
  • Click on Printer and run the troubleshooter
It will search for problems like spooler errors, driver issues, and network misconfigurations.
7. Reinstall or Update Canon Printer Drivers
Outdated or corrupted drivers are a frequent cause of offline errors.
To update:​
  • Visit the Canon printer support +1-801-878-6858
  • Enter your printer model and download the latest driver for your OS
  • Uninstall the old driver via Control Panel > Programs and Features
  • Reinstall the new driver and reboot your system
Mac users can do the same via System Preferences > Printers & Scanners > Remove printer and then Add Printer again after downloading the latest driver.
8. Restart the Print Spooler Service (Windows Only)
The print spooler manages print jobs. Restarting it can clear hidden errors.
  • Press Windows + R, type services.msc, and press Enter
  • Find Print Spooler, right-click, and select Restart
After restarting, try printing again.
9. Check the IP Address (Wireless Printers)
If your Canon printer connects over Wi-Fi and your router has assigned a new IP address, the old connection may break.
  • Print a Network Settings Page from the printer
  • Note the new IP address
  • On your computer, go to Devices and Printers, remove the old printer, and Add a new printer using the current IP
10. Reset the Printer (Optional)
If nothing works, consider performing a factory reset. This option is available in most Canon printer menus under Settings > Reset > Reset All or LAN Set
  • Keep your printer firmware and drivers updated
  • Avoid power interruptions during print jobs
  • Don’t overload the print queue with multiple jobs
  • Periodically restart your printer to refresh settings
  • Use a static IP address for your wireless printer to avoid connection drops
  • Regularly check the print spooler service and clear old jobs
When to Contact Canon Printer Support​
If your Canon printer still shows as offline +1-801-878-6858 after trying all the steps above, it could be a hardware issue such as:
  • Internal Wi-Fi module failure
  • Faulty USB interface
  • Firmware corruption
In such cases, contact Canon Customer Support +1-801-878-6858 or take the printer to an authorized service center. Have your model number and a summary of troubleshooting steps ready.
Conclusion​
The Canon printer offline +1-801-878-6858 problem is annoying but typically easy to fix. By following this detailed guide—checking connections, updating drivers, adjusting settings, and clearing print queues—you can usually get your printer back online quickly. Remember to maintain your device with regular updates and proper shutdown procedures to avoid future issues.
