Ok, I have some concerns about dual fuel pump setups that I'm wondering if they can't be solved with a oneway valve arrangment.
I have a MKIV Denso pump intank, and a walboro inline pump also. The concern is that when the walboro is not in operation it appears to be a total block for flow. So if it fails I imagine it would cause a very sudden lean situation and kill my engine.
My idea is to run a hose around the walboro, a bypass if you will, that has a oneway valve in it and prevents backwards flow to the tank if the walboro fails and allows fuel to go around it.
Or perhaps a Y pipe to 1 line from both with oneway valves?
Or am I missing something obvious here?
And sorry bout this, but I don't understand/have never seen a swirlpot or surgetank for fuel.
