Hey guys, need some help here. After simply replacing valve cover gaskets and cps o-ring, car will not idle/run without stalling. Starts right up but if you let it sit for a minute or two the idle will keep dropping slowly and then stall. Went through and checked for vac leaks in lines and gaskets. Checked and adjusted tps per tsrm, checked iscv, sensors, all good. Tried new plugs properly gapped today with no improvement. Still no codes have popped up either. Decided to check resistance on the coils and I think this might be where my problem is. According to the tsrm cold resistance in the coils is between .3-.5 ohms, I got a reading of .8ohms on all 3 coils. Anyone know if this would cause a condition like this. Also if I hold the RPM's around 3-3,500 you can hear it sputter/break up quite a bit. I'm thinking I just need some good coils, but I'm open to possible suggestions. Still running stock electronics/fuel also. Thanks.
