wont let me cancel codes.
supraman508
496
maryland
I have 2 codes that are 41 and 51.But when I disconnect both terminals from the battery and wait 3 min and check the codes again they still pop-up,any sugestions?2nd 2nd I can't find in the manual where it shows u how to set the Tps,what section would the setting be at????
mk3_7m
536
melbourne
Have you tried removing the EFI fuse ? If that doesn't work then maybe the codes have not been fully eliminated. I can't get rid of 32 since i don't have a HAC sensor
supraman508
496
maryland
That right I knew I was forgetting something.the DAM EFI FUSE thanks.I saw in the t.s.r.m the section that has the T.P.S picture but didn't show how to install it cause I can rev the engine high with the Tps disconnected but when I connect it it only revs as high as 3 grand.can somebody send me the link to set T.P.S please.
mkiiichip
1,434
WI
Are you serious? Click "next page" in the link I sent you. There is more than one page for everything.
And your TPS is junk.
