I'm stumped.
My car idled great after rebuild (at about 1000mi now). After rebuild, I set my base timing and the idle was just as it should be. After some time, the idle seemed to hang low after the car warmed up. When I stop after driving, the idle drops to 400-450RPM and then it slowly carries itself up to the 600-700 or whatever it should be (on the order of 30 seconds get up to the 600-700RPM). As soon as I take off and then stop again, it's back down in the 400's - and then repeats process.
I first checked my idle control valve. It wasn't too dirty and I can hear it do it's clicking when key is in ON position. I reasoned that this probably isn't my issue (esp since the idle eventually comes back up?). Next, I again reset my base timing. What's weird is that doing this solved my problem. I was stopping and idle was going right to the happy mid 600RPM range as soon as I pushed the clutch in. After another couple hundred miles, the idle slowly starting decaying to a lower and lower number each time I stopped. Now i'm back in the same boat. I then checked vac leaks with a mityvac and found no leaks.
I don't know what else to try. I have a SAFC2 and that was the last thing I installed, but I soldered it in and did it right. I checked the karman reading right on the unit as a stupidity check and that looks good. TPS also seems to read properly.
Does anyone have any suggestions? I am trying to get the bugs out before I install my fuel system and up the boost on the HKS sport turbo to 15psi.
Help?
Help?
