i have been searching for a while and trying to figure out this problem for a couple weeks now.
i installed an emanage a while back and found out it didn't work, so i removed it. then the car started idling like shit and threw the "no rpm signal code", and of course "over boost". Well i just checked my codes and there are none, but i have to keep the car idling with the pedal, and the car has a severe miss at idle, when i drive, it seems to go away. i let my friend thomas adjust the cps while i held it at 800rpm. it was right to begin with but he played with it a little, hopefully he got it back where it was. the cps is the only thing i haven't changed, only cause i don't have a spare. my fuel pressure was and is still set according to the tsrm.
things i've changed to identify the miss and rough idle: not in this order
ecu
plugs
wires
coilpack
igniter pack
isc
fuel rail
went from 550's back to 440's
went from lexus back to stock
adjusted tps a few months ago
I know it is a pita to diagnose problems without being near the car, but i could use some help.
ecu
plugs
wires
coilpack
igniter pack
isc
fuel rail
