Wiring Injectors to eManage on 1JZ
hockysa
Hey guys, as some of you might know the 1JZ only has 3 injector feed lines.
I'm currently trying to wire up the injector harness on the 1JZ but am unsure of how to do it.
I'm aware I need to double up the wires on the EMB
On the ECU pin out the injector feed lines go
Line1 Cylinders 1,4
Line2 Cylinders 3,5
and Line3 Cylinders 2,6
So when I double up do I wire it up
I/J CH-1 and 4 to #1
I/J CH-3 and 5 to #2
I/J CH-2 and 6 to #3
or
I/J CH-1 and 2 to #1
I/J CH-3 and 4 to #2
I/J CH-5 and 6 to #3
Cheers,
Benjamin
hockysa
Well this is interesting.
After some advice, I've now wired it up the ECU
EMB I/J CH-1 and 4 to #1 INJ ECU
EMB I/J CH-3 and 5 to #2 INJ ECU
EMB I/J CH-2 and 6 to #3 INJ ECU
and it won't start now.
It turns then dies almost straight away
Also I don't get why my interaction light is always lit orange without the USB cable connected
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
per diagram T-10 from the emanage manual,
Hook it up as in the emanage manual 'Example 2, inline 6 engines, the wires for channel 'A' and 'B' you can leave off, that's for driving additional injectors.
The ground wire is teed into the ecu ground wire, that's pin #E in the diagram T-10.
So for the emanage injector harness, you would connect from the Emanage side, Injector Channel 1 (Blue/Red) and Injector Channel 4 (Purple/Red) to the ECU side #1.
Injector Channel 2 (Orange/Red) and Injector Channel 6 (Light Blue/Red) to #2.
Channel 3 (Yellow/Red) and Channel 5 Pink/Red) to #3
hockysa
How did you come up with which channel to pair up?
Because I got those pairs from the ECU Pinout
attachment.php
johnd-mkiv
14
Essex
Can someone please confirm the correct way to wire these in, as there seams to be so many orders in the above :)
john
