Hey guys, I'm rebuilding my harness and I'm choosing the shielding material for my knock sensors, CPS wires and OX sensor. I want a good effective solution and I've found a few options. Mainly metal braid, conductive nylon and heatshrink tubing. The heatshrink tubing tends to be most expensive at nearly $100 for my desired lengths. Metal braid is the cheapest and nylon comes in the middle.
This one really stuck out:
http://www.wirecare.com/products.asp?prodline=CN
It's an 11 mil carbonized Nylon® monofilament yarn. Is this suitable for this type of application? Or should I be looking at standard metal braid? I've never dealt with custom wire shielding before so any thoughts are appreciated. I know some people will use a coax cable for the knock sensors, but I'm not sure that's the best way to do it. I'm using MIL 22759-16 wire and would like all the conductors to be rated for 150-200C, as the tefzel is.
Thanks!
Thanks!
