The PO removed almost all traces of the windshield washer setup and I've decided to finally add it back.
I've got almost everything back in except the hoses that go to the front nozzles. I found this diagram which helped a lot, I need the top part of the setup now.
I have the hose leading from the pump to where the nozzle hose would connect. The hose from the pump is bigger than what fits on the nozzle though. It shows a splice connection and a T connection, does one of those reduce the outlet size to the smaller hose? Or do those 90* bend adapters(85348D) reduce the size?
I was going to just get a T fitting and run some hose to each nozzle but found out the hose won't fit onto the nozzles. I just thought I would ask incase someone has replaced those hoses and happens to know the sizes or adapters needed.
