will an 7m-ge fit instead of a 7m-gte
demolition man
ct
i need to rebuild my 7m-gte for some serious horsepower i need a motor to put in it for the time being, will a 7m-ge fit in place, i don't plan on using the turbo or anything will it hook up fine?, if not what do i need to do to make it fit, and run
my gte will be out of commission for at leas 6 months and i need something so i can have an everyday driver
your help would be greatly appreciated thank you
threedguru
Self Proclaimed Mechanic
Jun 26, 2007
30
Texas
yes it will but your gonna have to change the wiring harness and unless you want to do that twice i would just get a daily while your building the other 7m.
s383mmber1
3,614
Somers New York
Yes this is very very similar to the ever so poular NA-T swap, just backwards. The only thing that will be "nonturbo" wil be the exhaust manifold, absence of intercooler and the NA block and head....
supradavenz
LOL HIES!
Apr 1, 2006
159
AUCKLAND, New Zealand
Wouldnt you need the n/a engine harness? considering the N/A ecu uses single coil+dizzy? plus the absense of the 2nd knock sensor so forth?
if not then, wow. Learn something new every day.
Dave
