wide tires on factory rims
supraman508
496
maryland
so i'm getting tires and i want to get 245/50/R16.will i have any problems when turning and will the tire rub against the shock absorber.
lagged
1991 1JZ
new rochelle
you can do 255/50, i had them and they were alright.
right now i have 245/50s with no problems at all.
EDIT:
i only have the 245s out back, and 225s (stock size) upfront. i have no idea personally if 245/50s will rub or not up front.
suprageezer
778
Southern California
Here's what mine looks like, keep in mind I prefer the tread width wider than the rims, this tucks the sidewalls in where they belong, it also prevents road debris from puncturing ther sidewalls. I know the fad is rims a few inches wider than the tread width I just aint into that fad, it just lays the sidewall out flat exposing it to easy puncture. Don't let the mushy response folks convince you it makes your tires mushy either, proper air pressure can easliy take care of this.
Dec 20, 2007
94
El Sobrante, CA
EDIT:
255 isnt too big? i thought it would be
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
+1 That wide rim w/ tire stretched on to it look is "gay for Moeman".
