I had just installed a 7mgte in my supra trusting it had been assembled correctly (dumb ass mistake). Engine was running rough so i checked the timing and it was way out. I started investigating further and found the timing belt was installed wrong. Both cam gears were at about 1 o'clock with #1 TDC. The guy I bought the engine from had said he had installed a new head gasket but did not know how to start the car (long story) So when it was out of time there was a slight "pop" sound and out come the white smoke. I then installed the timing belt as per TSRM and checked the compression, all cylinders were between 148 and 152. So i put it all back together and started the car and it was running very well until it warmed up and the white smoke came out again. I have now removed the head and found no signs of a BHG. There was a MLS and arp studs installed by previous owner. I have brought the head into a machine shop and the machinist said there is no warping and the surface is excellent(no further machining required for new MLS) Block surface is the same. I'm out of ideas as to what went wrong. Any thoughts? :dunno: I did notice the coating on the head gasket was gone between one cylinder and a cooling jacket. Is this where it blew out maybe?
