Which spark plug to use?
supraman72
Ballin out of control
Dec 28, 2009
Franklin
Which spark plug does anyone recomend for our 7mgte's Pushing about 15psi boost that is. I have heard NGK are very good but which NGK plugs in specific?
^not true. not all kinds of spark plugs are good for boosted motors. iirc coppers and iridium's are the only ones good for them.
i use ngk coppers which are about 2 bux a plug.
supraman72
Dec 28, 2009
Franklin
Ok thanks thats what i was looking for, NGK coppers
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
i was joking about the more $ part.
im running ngk coppers but i dont remember the gap spec off the top of my head
honestly this stuff has been covered.
have you googled "ngk coppers heat range"?
did u look at the online tsrm?
gaboonviper85
3,236
Northeast Philly
Kevin;1495970 said:
any . more $ more better. LOL
just make sure they are gapped to spec
you really need to stop talking!
Stock heat range is #6
supraman72
Dec 28, 2009
Franklin
no im new on the forum so to speak, what is the online tsrm?
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
The TSRM stands for T= Toyota S= Supra R= Repair M= Manual :beer:
I dont mean to be a dick but just to let you know the SEARCH buttom will solve most of your problems. Do your sear then ask question.By the way welcome to supramania.
isnms
United States of America
Oklahoma
i80.photobucket.com
Here's some plug numbers:
NGK Sparkplugs
• OEM NGK Platinum plugs 5275, BCPR6EP-N-8, .032 JIS
• NGK Traditional spark plug 2330 BCPR6ES .032
• NGK Traditional spark plug 6282 BCPR7ES .032 COLDER
• NGK Iridium spark plug 5689 BCPR6EIX .032
• NGK Iridium spark plug 5690 BCPR7EIX .032 COLDER​
Denso Spark Plugs
• OEM Denso Platinum plugs 3113, PQ20R-P8, .032" JIS
• Denso Traditional spark plug 3007, Q20PR-U .032"
• Denso Traditional spark plug 3010, Q22PR-U .032" COLDER
• Denso Iridium spark plug 5302 IQ20 .032"
• Denso Iridium spark plug 5313 IQ22 .032" COLDER​
Denso numbers courtesy of Zumtizzle
grimreaper
2,180
Dallas
I run this at .028-.029, I change them once a year when i do an oil change.
gottadiesel
Flyin Low
Feb 16, 2009
459
Vancouver, Washington
So curious why are you running them at a closer gap, would not the larger gap create a greater spark? yet the closer would be less resistance... just curious as to your thoughts behind it. I am going to be running the same plugs, will be installing as soon as I get my MSD wires in later this week
dbsupra90
toonar
indiucky
you want to run as large of a spark gap as possible without blowing out spark.
i always run coppers. platinum isn't as good of a conductor, but last a hell of a lot longer. which is why most oem plugs are platinum.
only plugs i've had any real issue with are bosch. i prefer the ngk plugs since they perform well and readily available.
