Which oil would you suggest putting on a stock JZA70 torsen rear end? I would prefer Redline oil as I can get it locally.
I've read that the Torsen rear end isnt as beefy as the 7M clutch type? Is it the actual Torsen LSD that breaks in the diff? Can I make the diff stronger by changing to an aftermarket clutch type LSD unit like Cusco, Kaaz or similar?
How can I check if the gearing in the diff is the shorter 4.10? My car is a genuine JDM JZA70 TTR with the recaros.
