Which mk3's have brake ducting for cooling?
te72
Classifieds Moderator
6,604
WHYoming
MightyAl;1873955 said:
If you are talking about the brake ducts in the front lip it was only the 1jz-gte turbo r that had them.
Correct. Should still be able to get the lip without too much trouble, but the ducts that were made for it can be another story... the way people treat the under-trays being any indication, I'm sure most of them have been tossed out by now.
However, could always make your own. If you don't need your fog lights, would be pretty easy to fab something up using that hole. ;)
destrux
1,183
10
PA
Fog light opening + silicone ducting + factory backing plates (my 87's are ducted so I assume they all have that?). Pretty easy.
You could also put a pair of NACA ducts under the front lip. That's how most of the high performance Audi's feed their brake ducts.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
I agree that youre much better off just making your own setup. There arent really kits out there, and the factory setup on the 1JZ cars wasnt exactly "impressive" anyways. It's inexpensive and more beneficial to just find out what works and having fun with it
