Which 2JZ-GTE T4 Manifold for MK3
jdemara
285
North Delta
Just wondering if anybody on here has any positive/negative experiences with certain 2JZ-GTE T4 exhaust manifolds in a MK3 Supra.
I am trying to decide where the best place to get one from is...
So far I only know of driftmotion, and xspower.
Any recommendations?
Thanks all!
planemos
559
Slocan Park, BC, Canada
What you want to look for is a properly flowing one. I mean that the separation between the turbo hot side and the wastegate needs to be correct. If the angle isn't right then the wastegate won't operate perfectly. Kinda hard for me to explain but, for example, a tee is not the best way to plumb in a wastegate. You want it to be more of a wye. Sorry I'm a plumber lol There is probably a better way to explain it. I like the look of the "newly designed" driftmotion one.
jdemara
285
North Delta
i know what you mean.. a "Y" being better than a "T" for flow basically. anybody else use the driftmotion one and like it?
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Probably get better results in the JZ section. I have no input on this, everyone I know on an aftermarket single of any kind is using a cheap ebay manifold save one 7M guy.
