IJ.;1059718 said:
I can't think of a single reason to run Twins these days unless they're sequential.
Back when I did my TT 3.4L V8 I started at .3ar housings then ported the nozzles till I was happy with the response curve.
Yeah, Chris, I know you have ridden in a MKIV with the "true twins" setup....Boring.
We almost did a twin T3 35r setup on a 7M, but most hate lag, hence the reason I run a 35r, we had the manifold and such but scrapped the idea.
I would guess, and not much experience behind this, but 2 T3 turbos, depending on the front cover with an .86ar, 5500rpm??? But doubt it will go to full boost quickly.
SP is doing/did twin 35Rs on a 2J and stated it was far too laggy non-sequentially .
