So here's the story: I bought a new/used R154 to replace my 212k OEM that has serious issues shifting into 2nd and 3rd. The new transmission was advertized as having a slight grind while going into 3rd at very high RPM's, so I am tearing it down and rebuilding it to hopefully make shifting smooth in all gears.
Here is where my question comes in. Since the gears have been ground, the dog teeth have some wear on the tips. The blocker rings(brass parts) and synchro sleeves will be replaced anyways, but how much damage can the gear's engagement teeth take before the gear itself needs to be replaced? I have worked on transaxles that have had the teeth completely worn flat, which obviously required replacement, but where is that line of still being reusable?
Pics to accompany story
These pictures are of 2nd and 3rd gear, looking at both gear's engagement teeth, but the blocker rings can be seen as well. Focus only on the steel(gray) synchro teeth, please **We're talking about the synchronizer system here, not the actual gears' teeth**
2nd gear:
3rd gear:
Any attempts to get closer shots ends up very blurred (even in macro and super macro mode) I will disassemble the transmission completely this weekend, and may have better shots then but for now lets go with these.
2nd gear:
3rd gear:
