Jimmysmk3
79
Oakhurst, NJ
right, but u have fender rolls. I'm not gonna have that so I was just wondering if a 45 mm offset will fit in the fender w/o a roll and not rub the spring
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I am running a +25. Depending on what you do it can clear. I mean.. I have no issued with running a fat tire on it too, but I am really low and running a decent amount of camber. If you are willing to stretch (which on a 19" is kinda hard) it can be done.
Jimmysmk3
79
Oakhurst, NJ
well I'm on stock suspension. the thing is I have rims right now. 18x9.5 in the back with a 20mm offset with a 275 on the rim and they stick a 1/4 inch past the fender and the tire is getting peeled like a potato peeler is on it. from what i understand from reading this thread, a larger offset will tuck the wheel into the fender more. I fount a set of rims I would buy but they are 18x10 with a 45mm offset, so I just am not sure if that will rub the spring. am I correct on my understanding of offset and placement? a larger offset will tuck it in more? and would a 18x10 with a 45mm offset fit w/e hitting the spring?
Jimmysmk3
79
Oakhurst, NJ
ok, well then this last question goes out to anyone running a 10inch wide rim with a 35-45 mm offset. does your tire rub anywhere? inner or outter?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
garagefujimoto;953589 said:
How low are you BorHor?
To keep it equal, measure from a flat road at the front edge and rear edge of the "side skirt" , up to the bottom edge of the black trim.
20". That is without my audio stuff in the rear.
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
BorHor;953907 said:
You also have to consider hight differences and differences in the alignment. Wheel fitment is basically a game.
Such a fun game. I've been playin it for years, results improving each time.
I'm at 19 F and 20 R. No audio.
On 18's
With huge width F and R
I could not go any farther without cutting the car severly :)
rodel
SoCal
May 19, 2005
2,266
SoCal
Test fitted my GS rims.
Volk Racing GT-C - Special edition RMC finish (black chrome)
19x9.5+24, high type, concave center
275/30/19
The fender has to be pulled about 1/2 inch and the tire may have to be 255/35, 265 max, so that it tucks in.
