funkdoctorspock8;1849998 said:Was wondering if you have the wheels on your Supra. Any pictures?
ryansmith;1856152 said:I have been thinking of 17x9 + 15 (maybe) all round 5zigen fno1rc bronze colour
or
17x9 + 30 enkei RPF1 all round
Any thoughts?
Kel;1857126 said:So i have xxr 552 18x9.5 all around with 25+ offset with 245 / 18 / 40 all around and the fronts are rubbing really bad inside the wells when i turn. any suggestions?
sylquebec;1849021 said:Finally, i received my wheel.
Model : Varrstoen 1.1.1
Rim size for all 4 : 18, 9.5 width ,+30 offset
Tire : front 235/40/18 Rear 255/40/18 Yokohama avid enVigor
In front, I will need to roll...or push where the 2 screw tighten the plastic inside guard and it should be ok, I hope.
In rear, i'm not sure at all. I tried to compress the wheel and it look like it will clear. I also tried to jack the car on the opposite side to compress the wheel but it look it doesnt camber the same way so I dont know if its a good test. Let me know please.
I would also like to know if i should keep the rear wheel that size or go with the 245/40/18 instead of 255. It would help to clear the rear lip + car height will be more even front to rear.
ryansmith;1857649 said:This would be quite similar to 18x9 +22 then? I may be picking them up tonight if they fit nicely.
How do you like this set up would you change anything? I'm planning on being 50mm lower all round (around two inches)
sylquebec;1857688 said:They will be quite similar. you will need to roll the front like me. Rear will be hella flush if it clear
For my wheels...i would not changhe anything
ryansmith;1857690 said:How come the front needs rolling? in the photos yours looks like it's going to clear, I am pretty sure I will be as low as you also so do they rub on full lock? Rears need rolling in your cars or are they sweet?
they are coming off a s15 with 215/40 rear and 225/35 front :nono:
sylquebec;1857849 said:Rear are ok, front rub when wheel are almost full lock (turning in a driveway, etc.)
It may clear on your car since your tire are thinny.( too small for a supra)
Korg77;1859685 said:all 9,5 +30, 265|rear, 235|front
