whats all needed for the hydro fan set up on a 1jz?
cpederson
117
wi
i have the stock rad, fan, with pump, resvoir, and of corse the hydro water pump on the engine.
what else is there?
thanks corey
cpederson
117
wi
i have the rad from the stock 1jz clip
10secdream;1519776 said:
You need the rad with the temp sensor in it. Do you mean stock JZA70 rad or MA70? Also I think you need a hydrofan ecu as well.
csnow
Matthew 6:33
Palm Bay, FL
You also need the oil cooler.
1) radiator temp sensor (the sensor will thread into the drain hole if you have the factory radiator)
2) ecu
3) pump
4) reservoir
5) oil lines
6) cooler
7) fan with shroud
cpederson
117
wi
im going to need help on how all the lines run and how to hook up the cooler. if anyone has a diagram. alo does anyone want to sell me the fan ecu?
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Everyone just slaps on 2JZ-GTE complete water pump housing dedicated to just the engines cooling with mechanical fan or E-Fan.
You cant just go to autozone and pick one of these things up you know.
I think I have a hydrofan ECU around here somwhere
