What is this warning light?
SupraStoked
I just started getting the code 52 ecu code about the knock sensor and this warning light started to come up along with the engine light. I never knew what it was for, i guess im just curious. I also got code 51 about the tps because the harness that clips on to it broke a little bit..does anyone know how i could go about getting a new connector? is that possible?
kotu100
1,899
Easton, Ma
Yea thats your coolant reservoir light.
Also make sure you dont have the a/c switched on when you're checking codes, that will cause a 51 as well.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
IJ.;1735265 said:
BHG Light "Bird Has Gone" ;)
Seriously just the low coolant light, top up the reservoir.
te72;1735522 said:
Dammit Ian, you beat me to it...
I always thought of it as a cheap G-meter. If it comes on, you're approaching your tire's limits. Adjust fluid level to according to tire grip capacity. :D
Btw buy a manual.
Warlock1
67
Surprise, AZ
Welcome SM and as someone stated before, grab a manual and just start to read through it. It will help you through many more issues you will inevitably come across with these cars.
SupraStoked
LOL "Bird Has Gone" ..Anyone know what the hell that symbol is supposed to be anyways?? Problem easily fixed by the way..all fluid levels adjusted according to tire grip capacity ;)
I have the Haynes manual but i couldn't find anything about the warning light..weird. But thanks for the info everyone!
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
RiyadYar
384
NY
it possibly came on because of a blown head gasket check your oilcap to see if its milky or do a head gasket leak test
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
The symbol is a radiator. Buy a Owner's Manual, and while you're at the dealer buy a TSRM (Toyota Service Repair Manual, ~$50) and throw away your Haynes.
