okay. 86.5 NA manual. it ran rich. real rich. gas out the exhaust rich. checked the timing. 22 BTDC..wow
brought it back down to 13. adjusted the idle screw back to around 1200 rpm.
no power. none. it dogged from 1200-3000 rpm then barely picked up past that.
screwed with the idle air screw, nothing. brought the timing back to around 2000 and it was back to normal.
what is this timing supposed to be at because under manual it says 10-13 BTDC. i haven't changed the cams or anything else in the car. stock internals. and i can't just say "ahh i'll just leave it at 20" cause it's squirting gas and i'm pulling 14 MPG right now :/
